Oil tube (driver side) replacement
Skip
I have a leak at the rear most oil return tube on the driver side. It's a two piece tube already with a circlip and the leak is coming from the crankcase seal side. I have a replacement two piece tube, but recommendation is to remove the heat exhanger - bolts are quite rusty on the engine block, so am concerned about breaking them off unnecessarily.Any recommendations?
