I have a leak at the rear most oil return tube on the driver side. It's a two piece tube already with a circlip and the leak is coming from the crankcase seal side. I have a replacement two piece tube, but recommendation is to remove the heat exhanger - bolts are quite rusty on the engine block, so am concerned about breaking them off unnecessarily.Any recommendations?
I have always removed the exchanger. Take your time removing the exhaust nuts and often heating them is required.
I have had good luck installing them without removing the heat exchangers. The trick is to put a small hose clamp on each side of the new expandable tube,lube the o-rings and then useing two small prybars or screw drivers pry them(expand) into place. Very easy this way.
Interesting idea - I guess that way it gives you a leverage point. Thanks - will look at that options also.
