2003 996 Cab, 68k miles
I have the Durametric code reader software
The check engine light has come on 2 times with the following codes
P0491 Secondary air system bank 1
P0492 Secondary air system bank 2
And 9114 PCM control unit. The software does not allow me to clear this code
Any help with the codes and cause is greatly appreciated.
P0491 Secondary Air Injection System, Bank 1 - Insufficient Flow
P0492 Secondary Air Injection System, Bank 2 - Insufficient Flow
Possible cause of fault
- Electrical fault in power supply or line between relay and secondary air injection pump
- Secondary air injection pump relay mechanically faulty
- Mechanical fault in electrical secondary air valve
- Pneumatic secondary air valve faulty/sluggish
- Electrical fault in secondary air injection pump
- Mechanical fault in secondary air injection pump or secondary air injection pump blocked
- Vacuum system leaking
- Air hose to secondary air injection pump slipped off or constricted
Time to finish the thread.
The final problem was a leaking vacuum reservoir (part 933 110 140 03) behind/lower then the alternator. I would never had found this leak as a DIYer. The shop smoke tested the system and found the leak. The leak was not obvious thus the post and part number.
part $27
Diagnostic prior to repair 1.5 hours
Alternator R&I 1.0
Retest 1 hour
