2001 996 Temperature Sensor Location
Loren, I have the coolant drained from the engine since I am replacing the water pump. Is this the time to replace the engine temperature sensor, while there is no coolant in the engine? Am I correct assuming the sensor measures the water temperature?
Thank you
