All the problems with the car always happen just before the holiday!!
Since 2 days my front right turn light stopped to work! I said "doesn't matter, I will change the bulb (P21W) and all will be ok!!!"........Surprise!!! I open the front light and I discovered that the bulb was ok, I changed the bulb, to be sure, with a new one.....but the turning light is still not working!!!
What can I do? Any Idea?
Same problem here. I changed both sides to even out, worked for a couple cycles, then off again. Then the other side!... what's going on?
To make sure, I sanded out the metal tabs on the socket, but not yet the metal tabs in the housing (but it looks good though). Are there a "Control Module" for the lights?
It is simple to with a voltmeter - either there is voltage there or not. If one light works and other does not then I doubt it is the control module.
There have also been faults with the electrical connector that hides in the fender. When you install the light assembly it can cause a misalignment and poor contact within the socket.
Hello Loren,
Do you have the pin-out of the socket? Kind of hard to check for the voltage without knowing which pin is what.
