Per the Porsche TSB "Summer Wheels and Tires" (which you could read if you were a Contributing Member ;) ) the widest tire on an 18" rear wheel is 265 x 35.
Rear offset can be 52 mm on a 9" wide wheel or 47 mm on a 10" wide wheel (with a special clip to move the parking brake cable over). I'll correct what I said previously... technically you could make those wheels fit with some adjustment of the parking brake cables.
We are taking a tight fit and no snow chains etc.
