RUF pedal install?
If you have a set of small "C" clamps it will help you greatly while installing the Ruf pedals because you can drill right through the holes in the pedals and be certain of your measurement. :)
Thanks, I've got them all on except the accelerator but I'll try the C clamp idea because I had a hard time with the drill bit wandering on the metal brake and clutch pedals. The dead pedal was easy because I removed it from the car and drilled it on a bench.
Karl
Jeff: sorry I didn't get back to you. I also got mine from Weissach. I just missed getting a dead pedal with the RUF logo on it. The new and subsequent shipments do not have the logo on this pedal. :(
And no issues at all with their use.
