A new problem popped up today with my cab. My roof opens, but the decklid does not close. The display gives an error: roof not fully open (or something simular). Tried it 4 times and the last time it worked. Drove away with my top down and 10 minutes later, on a roundabout, the error message popped up briefly.
I suspect that the sensor needs cleaning. I assume that there is a sensor that detects that the roof is folded down and that the lid can close. Any idea where is is located?
Regards, frank
Hi Loren,
Thanks for your reply.
ok, any way I can visually inspect the microswitches? Don't really have time now do drop by the dealer.
regards, frank
error says:
convertible top not in limit position.
tried it 5 times in the last 20 minutes. Worked once. Top goes down completely. Then I hear noice of the engine, but nothing happend. Then after 5 seconds the roof stops and the error pops up!
Any suggestions?
Regards, frank
Hi Loren,
regards, frank
