"Clunking" when turning
I had something similar with mine. I was getting a clonking noise when manoeuvring at low speed, usually on anything more than half lock, and most often when reversing. It was the shock absorber top nut was slightly loose. I found it after checking the TSB's for the 996T.
Might be worth a try.
