I've noticed the last few times that I've taken the car (2005 987) out that the brakes are becoming harder to push. Braking is taking longer than it feels like it should. Any ideas?
Thanks in advance,
Jason
When did you last change the brake fluid?
Thanks for the response, Loren. I've had the car now for two years. I purchased it with about 30k miles on the clock and it's now at about 45k. In that time I've had an oil change, clutch replaced, RMS leak repaired, and the 40k mile maintenance done. I'd imagine the only one of those services that could possibly include a brake fluid change would be the 40k maintenance. So, If the 40k maintenance doesn't include a brake fluid change then I don't know when the last time that was done would be. Is it time?
Jason
