996 Power Steering Leaks
I have a 2000 996 C2 with 88,000 miles. I have power steering fluid leaking, and see it on the floor in two spots. One is under the engine on the drivers side cylinder bank. The other is below the drivers side of the steering rack. Are these typical and does anyone have DIY instructions on the fix. Thanks.
Not common but both need to be fixed ASAP.
The leak by the engine can cause a fire (and has).
The leak in the front can cause a sudden loss of steering.
You need to clean the area and find out where the two leaks are coming from.
Will do. I'll get it on the hoist today. Thanks
