Removing secondary air system pump????
Hello does anyone have ever triyed to remove the Secondary Air Injection System pump? I live in a country with no emision regulations and this pump is lighting my engine light from time to time, so I want to get it out, do I have to do modifications??? or just disconnected... thanks
Loren is correct that you must disable the pump using the dme. You also will lose control over the changeover valve that controls the resonance valve in the intake. You will have to find some other way to properly control this valve if you want you engine to have the proper power curve. Without it, the performance will suck.
