We are installing an 997 3.6 engine into a 2003 Boxster, and trying to find out what hose attaches to this aluminum pipe sticking out?
Not sure if this is it, but appears to be. I attached a PET Diagram for you. Looks like tandem pump and goes to a heat exchanger...But I could be wrong. Hope the diagram helps.
Good luck,
DC
tmp.pdf
