997-1 S - PCM faceplate removal HOW TO
I want to paint the silver center PCM console's faceplate to match my car's exterior color flat black. The soft paint is all worn out and white is showing through.
Pulling the PCM is easy but feel like an idiot for not knowing how to remove the actual faceplate PLEASE HELP!!
:help:
Edited by slahti
Yep that's the one did find a post on removing it. But I am wondering on a 997 if you remove the Radio do you need codes to put it back in.
:help:
