I am sure many other look at inside wear on their expensive rear tires and wonder. It occurs to me that when you sit in a car it settles slightly. Given the arc of the control arms, this contributes to an angular change in the camber. 1/4" settle on a 20" swing arm is about 0.7 deg of negative camber. So my question is, is the camber adjustment specified in the 'loaded' (driver on board) or 'unloaded' state?
:welcome:
All suspension specs are full fuel tank, vehicle with spare wheel/collapsible wheel and tools, but without driver and without additional weights.
