ok its very simple all u need is 4 zip ties
i work at a shop and been fixing boxster tops for years this way works every time never had one come back lol
open the top half way
removal the headliner 2 velcro straps
make sure the straps are screwed in lol (ok i know they strech out and this is the fix) :)
take one zip tie and push it into the small hole on the plastic runner that the top is sowen onto there is a hole already were the plastic square pushes 2 the frame of the top and zip tie the top down 2 the frame very tight
ok now try the top lol still not fixed right
take another zip tie and put threw the top circle strap is elstice and zip tie it threw the other zip tie already installed!!!!! and pull tight
i sware 2 u that the top is tight and working now :)
repeat on the other side
sorry about spelling haha
:welcome:
What model year and car are these instructions for?
  • 5 years later...
Thanks clellee3 for this tip!
I've got a 2010 Boxster that needed this. I found various other fixes (including unscrewing the screw and pulling the elastic strap tighter using an existing hole — And replacing the elastic by sewing in another piece). I can tell you that there is almost no room to work without taking a bunch of other things apart. I had to do this 1 handed and so I placed a small LED headlamp in the cavity because it's super hard to see anything as the Boxster top does of good job of blocking out all light. I did the project slightly different though. I ran the zip tie through rear most (reachable ) hole in the elastic, then ran the other end through a hole 5 spaces further. I zipped the tie to about the size of a half dollar and then tested the tension to see if it would track. It did, so I snipped the end off and repeated the process. Good luck to all!
Update. This zip tie fix worked well for about a year. I had to tighten the zip strips once. WARNING: Be careful not to over tighten. I did on my passenger side and the elastic ripped off the canvas flap that attaches to the roof. I thought, not a problem, I'll just sew it back on. In doing so a cord became disconnected from a neighboring part. I reconnected that. When I closed the roof, there was a big "bump" sticking out. I'm not sure what it is and how to fix it. It's messed with it for an hour and got everything looking 95% right with the top closed. It's winter here now so I don't take the top down but this spring, I'll have another go at it and might have to take it into the shop to make sure I didn't break anything. Just wanted to give you guys a headsup.
