Could someone please explain how I remove the cowling and carpeting from the front boot in the 997 with 4 - wheel drive.
I have a CDC and Navigation DVD drive which are fixed to the walls of the boot and I can't figure out how to remove them. (I assume they have to be removed first). Also the upper rear cowling has about 6 screws in it, which are easy to remove, but it still won't budge.
If anyone can give step by step directions, that would be great.
Ross
Okay. But how do you remove the plastic box that surrounds the CDC and DVD drive? Do I just pry it with a screwdriver and expect it will pop off? I just don't want to break it as you can imagine. I don't see any screws holding them in place.
Ross
