2001 996 Carrera Cab, 6 speed manual trans.
The car has 20k miles on it but the tires are old, based off the tire code i think they are ~7 yrs old. The previous owner barely drove the car. They have a little tread left on them, but could really use new tires, i am trying to nurse them thru one more summer as this is a dry weather summer car only.
At highway speeds on smooth roads i notice a vibration in the steering wheel and seat, from ~70 -84 mph over 84 it seems to smooth out again. From 70 up it starts out slight and then gets worse until i can feel the vibration in the seat.
Is this a mechanical issue or tire/balancing issue?
Certainly if the tires are worn or worn unevenly it can cause vibration.
Or tire pressure, road surface can contribute.
Then balance.
Then alignment.
If the tires are that worn, I wouldn't try to nurse any more miles out of them in a climate like NJ's. Even a summer-only car can get caught in a sudden rain shower, and fast cars on worn tires are dangerous in the wet.
I had the same problem with my old Boxster but my tires were not very old. I had the alignment and balance checked and they were ok. The problem turned out to be 2 tires had flat spots because it sat on the dealership lot for a long time before I bought it. They could actually see the tire out of round when it was spinning on the balancing machine. It wasn't hurting the car but it was a bit annoying.
  • 4 weeks later...
i took the car to a local porsche only shop. It turns out all 4 wheels were out of balance, and all 4 tires have flat spots. They balanced the wheels as best they could and the vibration at high speeds has gone. What i did notice wa a slight vibration at lower speeds 30-40 mph. once i replace all 4 tires and balance i'm sure this will be resolved. At least i know the cause was bad tires
Glad to hear that you found the problem and the tires were not new when it happened to you. My tires always flat spot a little because the car will sit for a month or more at times. I have only had one set that did not round back out after I got them hot. Hopefully it will not happen to you again. Happy motoring and enjoy the car. :)
