Hi, I've just downloaded the app but when I attempt to login I get no where. I've tried resetting the password but still no luck.
Please advise?
For the iPhone?
If so, that is the forum maker app. Make sure you have the latest version.
Both TapaTalk and Forum Runner are also supported here.
Ok, thanks. Still can't seem to login tho..
Perhaps the login for iP requires a different user name and password ...
'IPB Mobile' for iPhone 4s
The bug report at IPB says "Could you try deleting and doing a clean install of 2.0.1 It is a corrupt record in the sqlite database which was made in 2.0.0."
So they are suggesting you remove the app and then do a new install.
