Anyone know how to take out the PCM module?
I am trying to swap my OEM brushed aluminum for the OEM carbon fiber trim. All the parts on the door and the dash strips were done rather easily however, I am now stuck on the center console part.
It took the shifter trim apart, got the center console trim loose but there 2 clips from the center console trim that is underneath the PCm module.
It seems like the PCM/Nav unit might need to be removed.
Anyone have any idea how to remove the center vents so I can get to the screws on the PCM module?
TIA
Frank
The horseshoe trim around the PCM can be replaced using a dental hook, start at the bottom of each side and gently pull, then work your way around. VERY easy
The flat section has 2 screws at the back and then just lifts up and slides back as i recall, there are no more screws
Edited by mudman2
who is the tutorial on how to remove and do a bunch of things with a PCM. find a video you need and it should help you out
http://www.6speedonline.com/forums/cayenne-955-957/192424-porsche-radio-nav-pcm-2-1-faulty-screen-replacement-tutorial-video-how.html
it is on a different forum so get a user ID and a password and you'll be able to view the videos no problem. good luck.
