Airbag warning light with fault code 801b
Hello.
This one is for Loren....
I endup with an Airbag warning light with a fault code 801b. By doing some research, I found a TSB that lead to the potential cause of this fault code. ( Corrosion due to moisture in the door connection point.)
Here is my question, on the TSB 6953 there are no clear figure explaining where or how to connect the 2 upgrade wire harness, they are also refering to a workshop manual 2706in for connection of the airbag unit, and for control unit. Where can I find detailed informations for this TSB or about the WS 2706in ???
Fred
post-24675-0-77351000-1353841696_thumb.j
Thanks Loren.
From what I understand in this TSB, I need to rewired from the door side airbag to the connector, redo the connection inside the door connector, rewired from the door connector to the control unit, then redo the connector of the unit connector... Then reconnect the battery and hoping that the fault code is gone...
The service information speaks of one harness, differend on MY 05 and MY 06, running from airbag control unit lockated under the center console to the connector behind the side panel in front of the door. I cant see the need of a harnees replacement inside the door, otherwise there was need on at least two harnesses. This is what i undersand from the service information.
