Got a 2002 996TT (pre-most) with PCM1 and Bose sound system incl. rear subwoofer of which I would like to replace the head unit only and keeping the Bose amp and speaker setup. Probably covered a dozen times but reading mixed views on this especially 2 Ohm speakers and on output to the rear subwoofer which has his own amp so what exactly to be done?
Can someone help me with wiring diagram for 2002 pre-most with Bose and rear subwoofer as I can not find out from were the rear sub wiring is routed from.
The pre-MOST Bose amp is a bit odd, in that it amplifies the speaker outputs from the head unit, unlike the Harman amp which uses the line outputs from the PCM1. I'll drop you a PM with some details.
