Worrysome Traction Control Behaviour
This has happened 2 times now, both with identical circumstances and result.
Cold morning, cold tires, greasy road. Pulling out onto a road and accellersting "briskly". I'm assuming I encounter what race car drivers refer to as a "Traction Control Event". In the past, this would simply result in a short loss of power, then off we go. What's happening now is a significant loss of power ie, the engine speed drops to idle. I pushed in the clutch and the engine is running fine - only at idle RPM's. Worse, it does not repsond to the throttle at all. Once I pull over, turn the car off then start it again, everything is back to normal.
I'm going to hook up the Durametric when I get home, but there are no warning lights on the dash and the car is running just like it always has.
Anyone else experience this?
Hooked up the Durametric and got the following:
<log>
Bosch Digital Motor Electronics Motronic 7.2
Module Identification
Part Number 986.618.660.05 Supplier Part Number 004157029000 Current Fault Codes
P1508
Porsche fault code 408 - Function monitoring Torque comparison Signal implausible
P1505
Porsche fault code 404 - DVE control range Open circuit
</log>
Any clues would be most appreciated.
P1508 408 Torque Comparison Function Monitor – Signal Implausible
Possible causes:
Values from gain adjustment outside tolerance.
– DME control module
P1505 404 Throttle Jacking Unit, Control Range – Open Circuit
P1505 404 Throttle Jacking Unit, Control Range – Below Limit
P1505 404 Throttle Jacking Unit, Control Range – Above Limit
Possible causes:
Below nominal actuator current
– Open circuit
– Short to B+
Above nominal actuator current
– Short to ground
– Short circuit in triggering wires
I would reset them and see if they come back.
Perhaps some electronics cleaner on the throttle jacking connectors.
