P0348 Error code on Boxster S. 2003, 36,000 miles
On the old camshaft position sensor the round end of it was metal, the replacement is entirely covered with plastic. I understand that the it is and updated sensor, is this enclosed in plastic OK?
Abe
Abe
Can't honestly say I've ever seen an all plastic unit, the OEM units had metal tips:
Do you get a factory replacement or an aftermarket unit?
It is a Bosch replacement, I don't have the number here at work.
I'm sure Bosch knows what they are doing, but I have not seen one configured like that.  The sensor itself is a simple Hall effect style, and some other makes use all plastic housed units.  I'd give it a try and see what happens.
I was getting the P 0348 code, the check engine light would go on, then go out again, it did this several times, it seemed to go back on when revved around 4-6000 rpm. I replaced it with Bosch part number 0 232 103 092, it seems to be working fine, will have a 500 miles test this weekend.
Abe
Update; Drove over 500 miles this weekend and no codes, so plastic covered unit worked fine.
Abe
