Howdy Everyone,
I just completed a clutch kit replacement (clutch disk, pressure plate). After getting everything installed everything seemed to work great until reverse stops working.
I climb under disconnect the linkage and reattach it and it will works fine for a few minutes. A few miles down the road it stops working again. When I put in the reverse gear its like first gear or its just not letting me get all the way over but it sure looks like when looking at the shifter. I can repeat this process several times with the same results.
So here I am pinging all those great minds on here for help or suggestions..
Fire away with any questions you may have to help troubleshoot..
Transmission was lowered on a tranny jack sat there and was raised back into position.
2002 Carrera 3.6 6 Speed
