Click here to Donate
Serpentine Belt (Porsche vs Other Brands)
I fit a belt of a known manufacturer such as Goodyear etc, as long as you check it on a regular basis for cracking ( as you should on any vehicle) I can see no benefit from paying out for OE. Porsche don't make belts, someone makes them for them.
Attention must be given to the exact lenght of the belt, some manufacturers do not use the same belt size as OM. 1 or two mm. too short is not an immediate problem, but 1 or 2 mm. too long will result in slipping of the belt.
 +1.  We have seen a couple of aftermarket belts that the owner's installed and suffered slippage issues.  Not all belt are the same quality or even the correct size; stay with a known name brand to be safe.
  • 2 years later...
