Aftermarket DRL Tap points?
I know there are threads on this but haven't found one that answered this question...
A. Where can I find a 12v switched ignition spot that I can add a circuit (using a fuse tap or add-a-circuit)? preferabley in the wet box
B. Where can I find a good place to tap into the turn signals?
Is there a fuse? (Or 2)?? Or should I splice into the headlight wiring connector?
Does anyone have any definitive answers for these?
It is not too hard. Just remove the headlight and turn the ignition on followed by putting the parking lights on. The use a voltage tester and check which wire on the headlight connector is positive when the parking light switch is on.
