Boot (luggage compartmen release cable broken - how do I get in to fix
Hi all
Tough problem for me I am hoping you can help with.  The boot (luggage compartment) latch release cable appears to have broken on my 1993 964 3.6 Turbo and now I have no way I know of to get in to fix it.
The cable is still attached at the release leaver end inside the car below the steering wheel but is quite loose - so I have to presume it is broken at the front end somewhere.
Can anyone advise how i might get into the boot?
Thanks for any help you can give
Richard
Try the emergency release cable (item 29 in the diagram below). You may have to remove the right front wheel and wheel well liner to get to it.
(click to enlarge)
Thanks so much for coming back to me.  I can't follow your suggestion because I (stupidly) keep the security socket for my wheels in the boot - so can't get the wheel off :cursing:
I keep it in there because I thought if I kept it in the car someone could steal my wheels after i have spent a fortune having the rims rebuilt/refurbished....
