New here my 1st question. I'm rather baffled by the PCM 2.1 update process. My Gen 1 Cayman S with Bose amp has PCM 2.1 SW version is 3.3 on Level B. I recently tried to  Update to Level C with Multimedia Update disc 000.044.901.40 as per a Tech document I used a few years back to go from A - B with the relevant discs. After the process is finished the Software version is still listed as Level B 05024 ED/4705. The Navigation Map disc 2012 Europe reads fine Anyone else experienced this and if so did you manage to fix it ?
I don't think there is anything to fix. Level C only updates the navigation drive, so I don't think you'll see a change to the PCM software version. Did you check the navigation software numbers before and after?
Hello Richard. Thank you for the reply, i've not checked the Navigation numbers i forgot to do it. The 2012 map disc runs fine, I would have updated the Software to Level C but can't establish the disc part no. I thought that the Multimedia disc 000.044.901.40 would do it after running it. I would still like to Update to Level C but now confused if that's even possible, all the posts I have read indicate that the disc MY08 is the one to use.
Regards Simon
SW Version 3.3
Unit: PCM
Target 05024ED1/4705
Actual 05024ED1/4705
Entered Yes
Found Yes
Unit: System Software
Target 04514BD1/5104
Actual 04514BD1/5104
Entered Yes
Found Yes
Unit: Amplifier    ( Bose )
Target 000117500/3504
Actual 000117500/3504
Entered Yes
Found Yes
Unit: Navigation
Target:/
Actual 00174440/1308
Entered Yes
Found Yes
Unit: Phone
I didn't make a note of this
Edited by Simon Young
The Level C update only updaes the navigation drive, not the PCM head unit. I don't think you can update an early PCM head unit beyond 05024. If you were expecting it to change to 05395, I don't think it will. I have updated a few systems, and none have shown 05395 after updating.
IIRC, the MY2008 map DVD also had the level C update on it, which would have exactly the same effect as the 000.044.901.40 CD.
Thanks Richard, I assumed it would update the head unit.That would explain the fact of not updating as I was using the 2009 map but I had previously had a full set of update discs to change from level A a couple of years back. Next time I'm at Parr Motorsport I will enquire about Level C head unit update, just curious.
Cheers Simon
  • 6 months later...
Please could someone tell me if the 2012 maps for PCM 2.1 is the latest or is there a newer map set than 2012?
I have a Cayenne with the original 2005 map DVD but has the level C (05395) software.
Edited by angusc
Hi Richard, that's what I thought but on contacting an online navigation place they said there is a 2014 version that will be the last update for the PCM 2.1
I have ordered a copy and will update here if it actually did update the navigation beyond the 2012 set that I already have installed.
It would be great if Porsche could release the editing tools required to allow third-parties to continue updating the maps beyond 2014 if Porsche have now stopped supporting updates for the PCM 2.1 ........
Edited by angusc
I would be intrigued to know where the "2014" version originates.  The latest version Porsche list is still 08.2012.
When you get it, put the disk in a PC, and see what dates are shown for the data files.
post-4000-0-76406000-1443164947_thumb.jp
Edited by Richard Hamilton
  • 5 weeks later...
Hi Richard,
The data files are all 2012 so he scammed me. But at least the dvd also included the A to B and then C software updates so I now have for any future needs.
Sounds interesting, are there any details of the updates included? If that's a 2015 update DVD does that mean actually they used 2014 map data......?
