2004 Cayenne Turbo only 4 cylinders firing
I have a 2004 Cayenne turbo with 160,000 miles on it. Have had a rough idle since I purchased it a few months ago. Cleaned the throttle body, air filters, replaced spark plugs 5-8 as well as coil packs for 5-8. Still have the same rough idle with CEL mostly solid, although after replacing plugs and colis was getting flashing CEL (codes vary from P0300, P0305,P0306,P0307,P0308 to just P0305, P0306, etc.
I have tried just taking off the connector on one coil and it is the same. I tried taking all four connectors off on the 5-8 bank and still the same. Checked fuses, both Bank 1 and 2 appear and test fine.
Disconnected the MAF on that side and still the same.
Tried jiggling wires to no avail.
What can I possibly do next?
