Remus (or agency power) exhaust on Cayenne 958 S, opinions
Just curious if anyone has experience with the Remus exhaust on the 958S? I am looking for an exhaust with a deep and non-raspy sound (not like the GTS or the PSE seems to be) and the Remus seems it might fit the bill with a deeper note. Not quite muscle car sound but still pretty deep. Also looking at the agency power unit but not sure. I found some clips, most are for the turbo or the v6.
  • 5 months later...
  • 3 months later...
Is it possible to add a clip of your Remus exhaust sound?
I can try, but what I found was the online recordings do not do it (or most exhaust) justice. It is throaty without being obnoxious. Lay into the pedal and it really opens up. I get comments on it, just again today. The quality of the materials and the fit and finish are excellent. It came shipped ready to bolt on and was packed in molded foam.
It was ready to assemble after removing your old exhaust (measure twice and cut once with a good exhaust pipe tool). As a hint, if you do it yourself be sure to use oil when cutting the old exhaust, makes it cut 10xs easier and without crushing the pipe. I cut mine with a chain cutter without removing the entire assembly first, essentially right on the vehicle after setting my air suspension to the highest setting.
