Cabin Ventilation Panel Removal
Hello. I'm having a problem of no heat in the car. Both pipes behind the battery leading to the heater core are hot, so I suspect the temperature sensor on the right hand side of the dash is the problem.
After removing the circular cover and the three screws on the panel, it won't budge. Are there clips to contend with?
Thanks for any guidance.
Edited by wizard
