Server Lease Renewal/Software Licenses - Goal Reached!
A big Thank You to all those that donated to help us reach our 2019 goal (and pay the site operating costs)!
Just an FYI - if all members of this site had donated - then the cost per member would have been less than $0.06 each.
Thanks again to all of you that did contribute!
Doug_B_928
Assistance with diagnostic trouble codes
12 hours ago, Doug_B_928 said:
Update:  I took the car to the dealer a week and a half ago.  It had finally thrown a CEL and valve lift codes had returned along with a couple of misfire codes.  They were a bit bewildered.  They did find two injectors leaking and want me to authorize 8 new injectors.  They said there is a TSB on the injectors.  I'm wondering why change them all if only two are leaking.  Their technical advisor is saying that the leaking fuel injectors could cause the valve lift fault, but they can't be sure.
I'm very sceptical that the leaky injectors are the cause, not saying they aren't leaking, no harm in pushing them for the tsb if it free.
Have your tried to flush your oil? There is another method, it's old school and involves adding atf fluid to your oil for some km and then doing oil change and filter. The atf has the same kind of cleaning effect as engine flush.
Probably safer to go for the liqui moly though as we are not in the 1950/60's now.
Are they confident the hpfp isn't faulty and cylinder 3 is the first to feel the effects? I know it doesn't make sense but a lot of thing don't on these cars.
Share this post
Link to post
Me too.  But they know cylinders 2 and 6 have leaking injectors.  They are charging me for the injectors and labour, which is why I'm sceptical about changing all 8; especially since I also highly doubt that this is responsible for the codes and rough idle.  I suggested that they replace 3 injectors (cylinder 1 is also suspect; I'll probably end up having all 8 done so that they'll be known to be good) and when the intake is off we should be able to manually inspect how much the intake valves open (set each cylinder in turn to TDC on exhaust stroke and then observe how much the valves open on intake stroke).  If it's a stuck lifter (which in this case would be stuck in the high lift position) we should see one or more valves open further than the rest).  I haven't heard back from them since I made that suggestion so I guess they are thinking about it.
Share this post
Link to post
Yep, and, if the injectors (which I am still awaiting) don't fix it (unlikely) then the problem is probably one or more lifters stuck in the high lift position.  BTW, where is the best place to get new lifters for a 2008 Cayenne S?  I'm not finding them at the usual online suppliers (Pelican, ECS, Suncoast, Autopartsway).
Share this post
Link to post
Update:  All 8 injectors have been replaced.  I've put over 300 kms on the car and it is idling perfectly.  So, it would appear at this point that the injectors were, indeed, the issue.... time will tell for sure, but so far so god :).
Share this post
Link to post
Well that's great news!
I will be having mine ultrasonically cleaned as now the plan to sell off quick has changed and fixing up to top condition is the way I'm going to demand top dollar in a private sale bitting the bullet on more costs.
I expect I will make the car perfect and sell it to someone who really gets a great car with no issues. But hey live and learn
Share this post
Link to post
