I figured this out with some careful Matlab filtering. The signal is 0 to 13.8V. It goes to zero when firing.
Edited by ABQ997
On 996's, Pin 9 on the OBDII port carries the rpm signal (square wave. Frequency = ignition events). 997.1 may have it as well.
No, 997 does not have this either at the ECU or OBD. It is all CAN bus unfortunately.
How about pin D17 (or IV 17)? What was the rpm wen the above measurement was taken? The spike could be the self-induced voltage of the primary side of the coil.
