I have the Carerra 4s Cab. Has anyone noticed that it's very easy to go into reverse when you think you are going into first gear? This has happened to me several times at red lights.
Not that big of a deal, just wondering if this is common. Thanks.
KeithBeniot,
I have a 2000 Carerra 4 with the six-speed.
To prevent going into Reverse when I want First gear, I've recognized that for me & my seating position Reverse is when the gear shifter knob looks to be in front of the left screen of the HVAC control. First gear is when the R on the gear shifter knob lines up with the frame between the left & right screen.
Just my two-cents.
MNC-I
check the lock out spring mechanism in the shifter linkage.  Could be a problem, or a broken spring or washer.
this was a problem way back with the early chevy camaro linkage.  lock-out to reverse was known to fail.  Never heard of this in a Porsche.
in the early 911's, as I recall, reverse gear was to the left and up.  1st gear was to the left and down.  I think I have that correct.  there was simply no need to use 1st gear after getting out onto the track.  Ergo, the basic H pattern was gears 2, 3, 4, 5.  Porsche changed to the traditional H, with 5th up to the far right, sometime around 1977, just before the SC's came out.  again, as I recall
the primary issue with the 996 shifter is that it's easy to miss the shift from 2nd to 3rd.  Porsche is not a speed shifter car, like some others.
the shift needs to be smooth, allowing the shifter to easily and distinctly pass through neutral on the way up to 3rd.
The shifter  neutrally spring loaded to the 3-4 gate..very light spring pressure is overcome to move to the 1-2 gate, very stiff spring pressure is overcome to move to the R gate, light spring pressure is overcome to move to the 5-6 gate.The three different spring pressures give a different "feel" to the gates to allow identifying which gate your going into.The springs are in the trans case. Could be a broken/stuck/missing spring causing you to not be able to differentiate between the gates.
Edited by Porschetech3
agreed.
