Hi just had to replace my front drivers side air bag and reused the original sensor now I get air suspension workshop fault checked the height for the front and each side is a little off by a few mm and the back is a little higher, any idea how to reset this error
Vagcom can do it, when I replaced the upper control arm I had the same issue.
You need to calibrate the positions height again.
I'm not sure if the duremetrics can do it? Someone will chime in I'm sure to clarify. Or its a trip to somewhere with PIWIS.
