My Pcar is a 2003 996 cab. Recent AOS failure required trip to the dealer. AOS was replaced and 10K service done (car currently has 110K miles on the clock). I picked the car up a week ago. Ever since, I have noticed a difference in the clutch pedal. Currently requires less force to depress pedal. When starting from a standstill, shift from neutral to first or reverse not smooth, as if the clutch isn't fully disengaged. Any thoughts you might have concerning possible cause gratefully welcome. Anything I might be able to check also welcome. Finally, anything that dealer might have inadvertently done capable of causing these problems? Thank you in advance. Car still has original clutch and IMS.
Did the 10K service or AOS r&r involve removing the transmission? If so, maybe they re-lube the clutch parts and somehow didn't seat the shift cables well. You can check if the cables are knocked off their brackets under the car.
