I have a 2010 panamera turbo; did not come from factory with launch control; is it possible to add the launch control mode and not sure if you would need an entire different transmission or its an additional part that is included.
I believe the engine would be the same without any modifications.
Also does anyone have any specs of a 0-60 time with the launch control compared to not having that option
Thank you
  • 3 months later...
Here is a link to a sport plus add on.
https://www.suncoastparts.com/product/970SMS.html
”Compatibility: Fits 2009-2016 Panamera models with PCM 3.1”
I think Sport Plus /Launch Control get you about .2 sec from ~4.0 to ~3.8
Another feature of Sport Plus with the turbos Is that you can get over boost for about 10 seconds which can boost the max torque ~10% from 516 ft-lbs to 568.
Jet pack for passing.
Edited by Fulwild
Removed irrelevant info
perfect; thanks so much for the info; going to check it out further; i did read the link that stated the below; i have a flashed ecu file with approx 620 hp; do you think it would require a new flash file if the below is in reference to the dealer having to flash the ecu; not sure i understand the beloe
Software License: We submit your software coding to Porsche, and your installing dealer can upload this information from the Porsche network.
Just out of curiosity could you post total cost so others considering this will have the info. I think its a better track to sport plus than the sport chrono pack as original equipment but that could be because I have never found a use for the chrono.
Edited by Fulwild
