Something weird ( AGAIN OMG ) my car things the rear lid is OPEN ( but is NOT ) and because it thinks is OPENED, i cannot close my top!
HELP
Fuses, parking brake light on?
You might try the hand crank - just don't bend anything if you hear or see binding.
Likely best to re-calibrate the top once you find and fix the problem. I think Durametric can do that and perhaps the higher end Autel - worst case you will a shop with a PIWIS.
very weird...........drove it and when i got back started to work..............but know the reverse lights do not work......
do you guys know a good electrical mechanic? car was flooded so i always have all these electrical issues
i agree - my battery discharges alot on its own - i am not sure if when i did the cable connection i have connected things wrong, hence the mechanic
i am in NY and those Rennwerke  are thieves so i will not use them, if you know people from the forum or a good mechanic let me know
