HID lights auto level - passenger side stays fixed
I noticed that my CTT HID light on passenger side, does not auto level when i start the car. Noticed because I started seeing the light try to reset (blink momentarily), while driving. Then replaced bulbs, and blinking still persisted.
Then noticed when I start the car, that same HID bulb on passenger side does not do the auto level when car started and lights turned on. I am certain the blinking connected to the auto level not working. Trying to figure out the cause.
If you have advice, appreciate the help. Thank you.
Check the connection/plug/wire harness going into that headlight. Many times I've seen the level control not function because it came unplugged going over a bump or during a panic stop. The connection / mounting and retaining mechanism on those headlights is the achilles heel of the whole setup.
