Hello,
The topic says it all, is an alignment required after replacing sway bar end links?
Well, maybe not all... is there a recommended brand for replacement to keep close to stock?  I was thinking TRW, about $35/ea, from pelican, but am open to suggestion.
Sway bars do not influence the wheel alignment, you can easily replace them.
If i had worked on anything on front end I would perform an alignment. The suspension, links etc. are so sensitive to any movements and for what an alignment cost i wouldn't hesitate.
Sway bars are mounted on the sub chassis, front and rear, on the one hand and on the struts on the other, they have no influence on the adjustments.
I don't know what an alignment costs where you're from, but it's anywhere from $300-$450 for me... Obviously, it's not going to break the bank, but it's certainly not something I'd do unless it was actually necessary. When changing/replacing drop links, it's not necessary. Just make sure there's no static loading of the sway bar on level ground and you're all set...
"they have no influence on the adjustments."
^^ This ^^
