:soapbox: My 987 boxster s (6wk old!), has had its drivers side condenser damaged by a stone resulting in the air conditioning not working.
The replacement is going to cost appx £650 ($1200).
I feel that this area of the car is far too exposed to potential stone damage, and there should be some kind of mesh or altered louvre design to help prevent this happening.
I believe that the 986 boxster s (which i have also owned), had a different intake/louvre design to help prevent this happening.
Has anyone else experienced similar problems?
all comments would be greatly appreciated.
You could try and get a body shop to put a mesh on the inside of the bumper. That way the radiator and the condensor is protected. I had a similar thing happen to my 986 (04). Had a body shop fit that it really protects
This is just the nature of the beast. The condensor HAS to be in an area where a lot of air can flow over it to cool it. You just happened to get unlucky and have a rock damage it. In all reality its pretty much just bad luck that it happened. No different than if a stone hit the windshield really.
