4 hours ago, IXLR8 said:
In the 993, I would simply pull the DME Relay. That cuts power to the fuel pump, etc. I could then crank my engine to pre-oil the motor after extended periods of storage.
How is that done on a 991?
Pull the fuel pump relay, will accomplish the same thing.
I looked at both the Service and Parts Manuals.  All I could find for a location of the fuel pump relay is what appears to be in the driver's side fuse panel footwell area and it seems to be a single relay, instead of a dual relay as used in the 993.
Will look for it when the time comes to pull the car out of winter hibernation.
Edited by IXLR8
Typo
