My passenger side high horn isn't working.  I replaced it with a new one and still no luck.  the connections and fuse look good and the low side is working.  any suggestions on what the issue might be?
Rod
2010 Panamera 4S
  • 5 months later...
My horns are intermittent, one day works, the next doesn’t.
Had one horn replaced once and it didn’t help.
I’m at 95k miles and thats been my only issue. I’ve learned to live with it.
2012 Base Panamera
A Porsche mechanic checked them when they reinstalled one of them. It worked for about two days.
It must be the wiring, I will check that myself. Thank you very much!
The steering wheel has not been off to my knowledge. I bought the car with 30k on it.
When I hit my lock button the horn sounds perfectly, not sure if that’s within the same system or not.
:welcomeani:
Did you test both horns when you did the replacement? The should always work when you apply 12 VDC to them.
Did you check the wiring to the horns?
Any steering wheel noises? Has the steering wheel been off before?
Thanks, I sort of assumed it was a different horn.
I will take you advice and change them out. I don’t like the sound of the factory horn anyway.
Thanks again for your help!
The alarm/locking horn is a different horn.
The front horns are cheap horns (on all Porsches)  - which is why I suggest testing them off the car with 12 VDC.
I replaced mine with electric air horns.
  • 5 months later...
So we had the horns go silent in ours.  Turns out replacement horns have swapped polarity.  If you just plug them in they will not work.  (The connection only fits one way).  I’ve been trying to pull the pins out to no avail to just swap them, instead of splicing in new connectors, 970-612-935-00 (Qty 1).  I’m not good at soldering...
Solution found.  👍
Read on from here:
WWW.6SPEEDONLINE.COM
Panamera - Weird issues with horn on 2011 Panamera 4 - I've had some weird issues with the horns on my 2011 Panamera since I bought it last July. When I first got it, the horn fuse (#48 I believe in the passenger side dash) was blown. I replaced it, and the horn worked for a while, though it seemed...
  • 4 months later...
Same issue on a 2011 Panamera Turbo... no horn at all.
Can’t seem to find much documentation on this issue - nothing on the horn relay, or the correct part or location - despite checking those located under the hood and battery locations; nothing under my passenger seat. all the fuses are good.
Have to remove bumper and verify that the horns are dead, but what are the chances both died at the same time. The wiring harness appears to be good based on the other features functioning properly (e.g., ACC, Parking sensors).
any further suggestions, links or images would be greatly appreciated
