Click here to Donate
Already replaced high pressure pump an high pressure sensor low pressure is stable at 80 psi at idle high pressure is at 780 psi at idle , did fuel volume test got 4 liters an in 1 minute .any ideas .
Share this post
Link to post
I also get reduce power after a bout 1 minute of run time I can see high pressure shut down just before reduced power mode kicks in i am using a Snap-on versus pro an a autel  scanner .
Share this post
Link to post
Sign in to follow this
