Hello I am getting the P0332 code on a 2010 Panamera S (V8). The car had been sitting for a while outside and I suspect the wires might have been chewed on. Can you please explain the location of the wires and how to get to them to see if they are intact or not. Also if it turns out that the wires are not good how can I fix the problem and what part do I need to get. Really appreciate it. Thank you.
(Moved to appropriate forum)
P0332 - Knock sensor 2
Possible fault causes:
- Loose contact or corrosion on connectors or line
- Short circuit to B+/ground/between lines or open circuit in the lines
- Knock sensor 2 loose or braced
- Knock sensor 2 Faulty
- Level Engine oil too low
- Engine Faulty (Mechanical fault )
