Just replaced my battery, after days of being dead, and now have problems with radio not coming on, fan not working, AC not turning on, etc.
Not sure why so many problems. Read that a radio code might be needed, but read later it is not needed on a 2003.
Any ideas?
:welcomeani:
Try disconnecting the battery negative lead - wait 5 minutes. Then re-connect the negative lead.
You will have to re-train the windows (hold up button for 10 seconds - then hold down button for 10 seconds).
You are correct MY2003 and newer should not need a radio code.
