Greetings:
I am blessed with a CEL. Durametric read the error code as P000A. I then ran short test and it came back with bunch of error codes but I couldn't find P000A. This  makes little/no sense to my untrained eyes/mind. The car is running fine with no noticeable degradation in performance or engine noise.
Can someone help me understand what is going on?
Thanks for your help!
Diagnostic Panamera P0A00.pdf
Welcome to RennTech :welcomeani:
Looks like you have a CAN gateway fault that has triggered a herd of communications errors.  I would suggest clear all the codes and see what, if any, come back.
Sometimes these complicated communications issues are a form of "brain fart" in the system, and actually just "ghost codes" that don't reoccur.
Thanks for the info.
This has  happened before and I cleared it. It went away and came back after  few weeks and approximately 2k miles. I cleared it again and this time it came back in just 3-4 days
You may be having an issue developing with the gateway controller, but that is going to require a PIWIS both to diagnose and code to the vehicle if it needs to be replaced.
I don’t know anyone with PIWIS and this does not sound like something an amateur should be messing with. I guess I need to take it to a dealer.
One last question. I am 200 miles from home and the nearest Porsche dealer. Should I drive or tow it?
Thanks again for all your help!
Cheers
K
You are in LA and 200 miles from a dealer?  Seems a bit odd.
In any case, the problem is one of various systems communicating with each other, so it may not have any impact on drivability.
I am at Death Valley National Park for the holidays. 🙂
