986 Triptronic with error code P0706
I recently pully my trans to replace the oil pump since it was leaking. After reinstalling the trans, I get a code P0706 and the lights are flashing on the dash.  I didn't have this issue before pulling the trans.  Any Ideas?  How do I check the Multi-function switch?
Welcome to RennTech :welcomeani:
P 0706 indicates the multifunction switch is disconnected or shorted to ground.  I'd start by making sure the switch connector is properly seated and check the harness for any breaks or other damage.  It could be the switch itself, but check that it is properly connected first, and make sure the shifter cable doesn't need adjustment.
