Convertible Top Calibration
Anyone local (Montreal west island) have a durametric that I can use to quickly check my convertible top calibration please?
All was fine until I had to do some maintenance related to drains, and had the roof in service mode for an extended duration. Ever since then, it won't function properly. Hydraulic fluid is full, and everything looks good mechanically.
Sadly, my Autel Pro MP series scanner does not support convertible top calibration on 911/996 (it does so on 997 and later models)... I can read live data and the potentiometers and the microswitch all appear to be within spec and functional. The hydraulic motor is not activating. The motor is fine, as I can actuate it manually and it does function.
Edited by rabit
